Menace2Authority
Thread starter- Joined
- Jun 11, 2010
- 38
Hey, was hoping someone here could help me out with a problem I'm having.
First of all, my motor is 1979 Mercruiser 165 hp in-line 6cyl. It has a Mercruiser drive.
1st problem: Is it Mercruiser 1 or MR drive? I'm ASSUMING it's MR due to the year
2nd problem: When ordering a water pump kit I'm being asked if it has a "flush plug" or not. I have no idea what or were a flush plug is or would be found. What I need to replace is the impeller, the 2 paper gaskets, probably the metal gasket (but it looks good) and obviously the "o" ring at the top of the shaft. I'm also thinking the upper housing as the hole in the top of the housing doesn't look very smooth. So needing these parts does it matter whether or not I have a flush plug?
Also.... I can't find any marina around that is willing to order me in the hinge pin removal tool. Are they Merc part only? Or is there aftermarket hinge pin tools available?
Having the same problem as #1 when it comes to ordering my transom seal repair kit. Is there a difference in the gimbal bearing and drive gasket? Or is it a minor difference that wouldn't affect me needing only to replace main gasket, gimbal bearing, u-joint bellow, and water pump hose?
Thanks.
Rob.
Thanks.
Rob.
