Re: Problems with 5.0 L OMC cobra
Since you are in the Norfolk, Virginia area, you will see some steam coming out of the exhaust. It's hot exhaust into cold water, happens all the time, so does carb ice. I had it today on a boat I was running, rebuilt engine, new manifolds and risers, new impeller, running 140? and there is white smoke (Steam) coming from the warm water out the exhaust. IT was 49? outside and the engine runs perfectly.
Melted wires will cause your engine to miss etc, and may even damage the ign. module. But till your run it and check the riser temp with one of those IR temp guns, don't go blaming a bad manifold or riser just yet.
IF that was the problem, when it starts missing and sputtering, shut it off and look at the plugs. If there is water it will be beaded up on and in the spark plug.
