Problems with tilt on Merc 115
plewis
The tilt on my 1994 Merc 115 has gone for the second time. This one was installed in 1999 at a cost of $1100 (Cnd). Was not too happy.<br />It seems like it might be the toggle switch - if I flick it often enough or in the right way it moves. Or sometimes it will work for a day then nothing. And i mean nothing - no noise, nothing.<br />Is there a way to test the electrical? Do the toggles go? The control is fairly exposed to the elements. <br />If I do need to replace the unit, can I just replace the electrical unit or do I have to replace the cylinder as well - they replaced the whole thing last time.<br />Looking for some direction.<br />Patrick
michaelbr1
Re: Problems with tilt on Merc 115
Pat, you should be able to replace each component individually. The switch and relays would be easy to do, the motor a bit more difficult but still doable. Don't let someone dupe you into replacing the whole unit again. It's not necessary.
plewis
Thanks Michael. I'll start with the switch - It's a Quicksilver unit so it should be fairly easy to find - and keep my fingers crossed its not the motor.<br />Patrick
