problems with V-belts 3.0 GS PNCA
aerobat
hey ! i have a never ending issue with quickly loosening v belts on my engine. after 2 hours of drive you have to retighten the belts or they will start to slip - especially the raw waterpump belt and the main belt .
am i doing something wrong or is it a thing that i have to live it on a v-belt and non serpentine belt model?
thank you for any hints !
Re: problems with V-belts 3.0 GS PNCA
Ayuh,.... Are the pulleys Rusted,..?? If so,... sand 'em, 'n paint 'em...
The Rust is like sandpaper, grindin' away yer belts...
The pulleys, Gotta be Smooth...
aerobat
thanks bondi - after replacing the manifold , the t-stats and many other things i hoped to screw enough on this engine - but now i will take a closer look on the pulleys- at least the engine runs beyond the belts like a champ with the fresh manifold :)
the pulleys are not fully rusted but also not fully rust free. do you know the 3.0 GS with v belts in particular ? its a pain in the ... to tighten the raw waterpump belt since its secured by two bolts ( one upper one lower) you have to loose and when you tension the pump housing it tends to cant a little and its hard to allign the pulley with the belt position perfectly. the other belts are not a problem regarding this.
thanks !
