Product to repair my gel coat cracks - advice needed
tommyboy050
There is a product from Evercoat called "One Step Finish Gell Kote". I am planning on using this product to fix all my scratches, cracks and deep cracks in my transom in
an attempt to keep the water out. What do you think or do you have something better?
kfouryou
Re: Product to repair my gel coat cracks - advice needed
I don't know about one step, never have used it,but I use marine tex .It's a 2 part epoxy , worked well for me.You have to make sure you dig those cracks out .I used a die grinder till you can't see the crack anymore.If you don't they will come back.Others should chime in and give you a more detailed solution
NYBo
Deep cracks may be a sign of structural damage, possibly from rot. You need to investigate.
