Products for restoring shine after wet sanding
chartersj
Wondering what products people have had good luck with after wet sanding. Do you compound with twisted wool pad and then go to a oxidation remover and then to a wax?
chevymaher
I used Meguires ultra-cut 105 and a buffer with a wool pad. Mine was originally sanded with 400 grit to get rid of oxidation as a starting point. then 1000 1500 3000 then buff. Then Ardex ocean polymer for wax.
Plenty of elbow grease......
Chev' has you covered on some of the cutting compounds. I use a variable and digitally setable rpm polisher to do my buffing. They are about $60 at harbor freight during the sales
chartersj
Ok sounds good. I have a porter cable dual action polisher as well as a Makita polisher/sander for the larger projects. Just need to find a wool pad to fit it
