Programmable Home H/C Thermostats
mscher
Need to take the plunge.
Any comments on units that you use/used and like or hate?
Thanks
i386
Re: Programmable Home H/C Thermostats
Only used one. Totaline P474-1050. No complaints. Have the same one at home as the server room at work. It's a fairly basic one.
Scaaty
Spend a few bucks more and get one thats backlite...used them for YEARS...only had to buy two new ones (like for the last two houses..zero problem)
rickdb1boat
For an inexpensive programmable, this one can't be beat. Installed many with no problems..
honeywell-thermostat.com/honeywell/TH4110D.html
jsfinn
I used to have a Honeywell programmable and it worked find, now I have a Hunter Programmable and I think it's so much better than the Honeywell. It tells me when the filter needs to be changed, automatically switches between heat and A/C, and has a button you press if you're home for the day so it'll keep the temperature comfortable all day where it might have cooled down/warmed up while you were away at work. The back light is a nice feature too.
I saw some no-name brand the other day at the hardware store that had a remote control - I thought that was kind of cool too... not sure how much I would use it though.
