archbuilder
- Joined
- Sep 12, 2009
- 5,697
Wood, two long bunks on the sides to support the sponsons, and a short one to support the center pod below the motor. Also I'm adding 2x6 guide rails on the sides, no rollers after the overhaul.
Here is a shot of one of the brackets I replaced where the original ones had been torched,
Here is the completed bunk bracket:
I just need to put the bunks on, drill them and the brackets....and other than the carpet they will be done. Here is the overall trailer.
I started with the cold galvanizing, but it was starting to make a mess. I'll pull it out later and finish up the other brackets.
I'm going to pull the hubs while I have a chance, repack and change the seals. It has bearing buddies, so hopefully I can just clean them up. It wouldn't hurt to sand the rusty axle and paint it also.
