Re: Project "Navy Top" 7/31 update... Done! Woo Hoo
Bill,<br /><br />I'm going to get a second set of hands this morning from my wife. I'll take your advice and do the windshield and aft ends next. I'm thinking that the windshield w/snaps should be done before finishing the rear. That way the front will be anchored while the aft end is pulled tight and marked for the pocket/tube the frame passes through. I did make a tube for the front bow, and it is sewed to the 1/2" of excess material from the front seam. That was a tight sewing job for me. Sweat every inch of it. So the front bow will only be held in place by being attached to the top, no straps to other bows. That is how it was done on a convertable top I had on a 40 Ford years ago and it worked well. <br /><br />My sewing skills leave a lot to be desired. Close inspection shows wavy stitches, even after practicing for a while. The problem is that racticing with small scraps is not the same as trying to stuff the whole top through the sewing machine! So I folded or rolled one side so it fits to the right of the needle better. But then you need to guide the left side too! I need 3 hands. <br /><br />Being my first top I'm not too worried about it looking perfect. I am more interested in how well performs under way. <br /><br />Regarding the frames, I only have two, the front and rear. The center bow is just there to press up on the second frame so it won't flap in the wind (I hope). I may have to do like you say and take a dart or two along the edge after strapping the whole thing down. <br /><br />If this top works well for the family, next summer I would like to try making a top with clear plastic side curtians and a rear skirt that extends to the leading edge of the splashwell. But first lets see how well I do with this one!<br /><br />Thanks again!<br /><br />Mark.
