projects other than boats
Well now I know what a 799 head is.
its the sister head to the 243 head..... LOL
the 243 head and 799 head are the best flowing stock LS heads that really come alive with a bit of mild porting. other than the C5 corvette motor with the 243's that got hollow stem valves, all other 243 and 799 heads have the same chambers and ports and stock steel valves.
the 243 is semi-permenant mold (A380 material), the 799 head is sand cast (A356 material), making the 799 head slightly stronger Higher initial yield strength. and a slightly higher hardness
because the head is slightly stronger, means I can port the head a little more, specifically getting closer to the tapped hole for the rocker boss
my main concern is the rocker stud boss break thru. all the people that CNC port the heads break thru on the intake side, and just leave it, then rely on a thread sealer to keep the motor from pulling in oil from the bolt threads. my concern is this leaves an airflow eddy. so I will need to install the bolts and some high-temp aluminum impregnated epoxy like lab metal, devcon or belzona, then dress off.
this is what I started with. crusty and oil coked. both heads had about an 1/8" layer of oil and carbon in the intake track. my guess the motor suffered blow-by from poor rings or the valve seals had gone. either way, the motor these heads came from was sucking in oil on the PCV system1773055533663.png
Redneck valve spring seat cutter
Just needed to make sure all the seats were golden for the new springs
Custom water cross-over manifold
Good news....parts are exactly like the CAD
Bad news....block CAD of LS3 does not match LS4 with some of the holes, and the front timing cover
Yes, the weldment leaked and while could have been saved, was a little skinny in some of the passages
tphoyt
I’m always amazed by how far and fast 3d printing has come. I got one many years ago for my son. He only has one arm and was printing his own prosthetics as a kid. They were cool then but now is just amazing what they can produce.
at work, we use plastic for the what-iff thougths, and once the thought is half-baked, we move into the carbon reinforced plastic, aluminum, stainless, titanium, etc for the prototypes
we are even 3D printing rubber parts and in some cases, tooling. have to go off-shore as locally in the states, its 4x the cost and 4x the lead time. takes about 20 days from PO to part right now
I don't think I've ever seen one of those before, what does it do.?
you wont. its 100% custom. its to relocate the waterpump and thermostat remotely to get the whole engine package as small as possible (see post #1 of this thread) and to tie all the water plumbing together for the two radiators I will be running along with the heater core.
most of todays vehicles have a water-cross-over manifold that also incorporates the water pump, thermostat, alternator bracket, AC compressor bracket and power steering. where everything sits in front of the motor. in a truck or a full-size car, its fine to add 7" to the length of a motor as there is the room to do that.
However for my project, I have actually reduced the size of the motor down to the length of the crank to get 425hp + into a vehicle shorter than most 4-seat golf carts. full build thread here. https://www.hotrodders.com/threads/1952-fiat-topolino-belvedere-project.550685/
flashback
Something tells me that you will need to remove the body to service the motor.!
No, because the grill and fender all go up together. I am considering a flip front (like E-30 BMWs). That's a minor detail compared to getting everything to fit while retaining the stock firewall location and the aft seats
redneck joe
sounds complicated.
Im just trying to buy mower
