- Joined
- Jul 23, 2011
- 53,453
I'm halfway through doing about 1200 sq ft of hickory flooring, can vouch for the blades getting dull. On my second miter saw blade so far...So the closet project is progressing. So far I have generated 18 bags of sawdust, each weighing about 35# taking the rough-cut 4/4 lumber down to smooth on both ends. currently at .963" and will probably size them to .938"
Hickory is extremely hard on planer blades. so in addition to saw dust, I have completely dulled a set of blades (both edges) will be swapping blades tonight.
regarding the Fiat project. been reaching out to some of the hot-rod and LS forums on cam suggestion. received 22 different cam suggestions.
so I took the more promising ones and did what any red-neck engineer would do. dumped them into Dyno 2000, verified the correlation with many of Richard Holdeners cam dyno videos.
and plotted them out
so the choice looks to be Texas Speed Magic Stick 3 or the Comp XR281HR.
at 2000-2200#, I do not need much of a bottom end as the car originally came with 16hp.
juggling and spinning plates...... I cant sit still.Lost of stuff going on here
reminder to get new miter saw and table saw bladesI'm halfway through doing about 1200 sq ft of hickory flooring, can vouch for the blades getting dull. On my second miter saw blade so far...
At least it will hold up well.
I use the Diablo 80 tooth ones for both seems to do pretty good cost vs performance. I paid $35 for my table saw at a yard sale, its funny to pay more for the bladereminder to get new miter saw and table saw blades
The admiral said......"why does it have to be hickory?"......." I would have been OK with pine" "i mean we are just going to stain it"
my response was "because hickory is 3 times stronger than pine and you overload the metal shelving in the closet now...."
