projects other than boats
So did inventory at work this morning.
This afternoon started working on the RV
Hacks at Lippert burned through the frame in a few places, then buggered more weld over it
Looks like Forest River did the same. 5 holes in a cluster, and a booger of weld in the middle.
Stuck bits of weld wire still stuck to the frame.
The coreplast belly pan was sagging. The wiring is just hanging everywhere under it, laying on the belt pan
Going to weld some studs and use P-clips and zip ties to clean up the wiring
Did have to make a relief cut in the frame to get the pucker out
Have the fish plates ready to weld. Cutting the 2x2 tubing to sister under the frame tomorrow
Found a bunch of what look like plasma cutter holes
Either way, the frame is straight and strengthened.
Strengthened the A-frame
Came to agreement with Forest River.... Getting a new friction hinge and stabilizer jack
Back down the shifter rabbit hole.
found the aisin transmission factory parts I need to move the shifter forward almost 8"
any salvage yard hunters, if you see a MK 2 Toyota Supra (1981-1986) with a junk 5MGE trans and a good shifter, looking for the MA61 shifter assembly. that is the 18" shifter
Just do not want to pay the price listed on fleabay
Alternatively, I can use the 19" assembly (I think from the cressida), however also do not want to pay the price below
going back and forth with a few guys on controls at work with an enginerd with a sister company..... I suggested he change his strategy because it will lead to warranty in the field....
he defiantly asked "what do you know about controls on boats" I said.... I did the door controls on this.
and i did the platform control system (electronic and hydraulic) on this. https://patents.google.com/patent/US9415979B2/en?inventor=scott+danforth&oq=scott+danforth
that is work I was doing about 4-8 years ago.
so...... trying to figure out how to get home as all the major roads around my subdivision are closed due to flooding
would post pics..... however......
southkogs
@Scott Danforth I musta' been really under a rock this past week - didn't even realize you guys just got run over by a storm. Was it hurricane status when it came ashore?
Just a little water. Mill Creek now 3' above the road
1000003708-jpg.634924
Not sure I'm still on the road. Fording 2 feet of water .
1000003712-jpg.634922
So, the other day while consuming a cocktail or three...... my thoughts wandered......
since getting everything to fit in front of the firewall is challenging...... why not pair the LS4 with an Audi/Porsche 6-speed and turn it into a mid-engined vehicle
these were the inspirations:
1971-fiat-abarth-jpg.634935
v=kHvHTKgEI2s
So....... went down a rabbit hole...... laid out this..... and realize the motor would have the damper up my back side . so that wont work.
1723047085196-png.634957
