Prop advise
MajorCorn
I just purchased a new Lowe Suncruiser SS 210 with a 115 Mercury 4 stroke. The boat has the 3rd log and the XL performance package and lifting strakes. The dealer said he was not sure on the right size prop so we started with a 13 and it can produce way to many RPM's. Does anybody know what is the best prop size for this boat or do i just keep changing them out until i find the right one...... Thanks in advance.
Dhadley
Re: Prop advise
A tri-toon acts very differently than a traditional pontoon. To recommend a prop we'd have to have more info - start with describing what "way too many RPM's" is. When you say the prop is a 13 are you talking pitch or diameter? What style prop is it?
At any rate your dealer won't turn it over to you if it's as far off as we assume it is. It may not be perfect but it will be close when he does make the final delivery.
