1977 ranger 17 foot with a johnson 115 first how far below the bottom of the boat should the prop shaft be next had a 13x19 ran ok pretty bad torque to right could not trim up very much without slip, whent to 14x17 with alot of cup extreme torque to right loss rpm and speed, tried 13.25x19 hp with solid hub bad torque to right and lots of vibration when trolling good speed low rpm do i need to raise motor. ps someone has put a spacer plate under motor which leans the motor out 1 inch at top PLEASE HELP
