Prop and engine height questions
Faztbullet
Yep you're 101% right, that's why stated not knowing if having the shorter or longer plates distance. If hasn't changed in over 25 years must be the old height style, motors you like playing with.
Your stating something that don't exist as there is no short or long plates distance. The plate distance on a 1977 V-4/6 is the same as a 2015 model. These are not old style motors ..you just have no experience with them.
Faztbullet
I looked today. The 4 blade is a shooter. I also was able to raise the engine a little. I was able to go 2 holes up which is about 1.5
Make sure you have the clip in blow out ring installed..
