Re: prop and motor heigth
What do you mean my set up is way off??? Max out how?? Im lost...
Dhadley is trying to help make sure the motor set up is correct...and save you some money and time by not buying the wrong prop. The motor has to be be mounted at the correct height for your particular boat for the engine to perform at its best. If the motor is mounted too low...too much of the lower unit is dragging in the water. That will lug the motor and drive you crazy trying to figure out how to get better hole shot, top speed and fuel efficiency. If you were getting 4,000 rpm at WOT...that's what Dhadley was reffering to when he said your set up is way off...your rpm's are too low. I think he's trying to recommend that you need to raise your motor ( Mounting height )..whether you can do that with the existing holes...or need to install a jack plate....I guess he could make recommendations if you posted some pictures.
The Cav. plate...or AV plate needs to be riding at the surface of the water or slightly above when you are up on plane. The plate is the wide horizontal thin metal deal that is just above the prop.
I'm zeroing in on a new prop for my re-power...so these are the things I've learned from guys like Dhadley and others. I've got my new motor mounted at the proper height...it makes a Huge difference on my rig. It will really pay to make sure your motor is mounted at the proper height and make sure the motor is running up to its potential before you start investing in props.
This mounting height, x-dimension, stuff takes a while to digest. Take the info. from these guys...learn as much as you can...then apply it to your particular boat / motor. I think you'll be very happy with the results. The guys here have been there...done that...they'll save you time, frustration and $$$.
Good Luck,
Wayne
