Have a new 11 ft Saturn SD330 inflatable, and used, ~2000 Nissan/Tohatsu 8hp 2-stroke, that we took on the water for the first time. Have an issue I'm hoping someone can help us with.
Bear with my terminology as I have almost zero experience with outboards.
For some reason the prop seems to cavitate (catch air?!) when we try to get up on plane, like a clutch slipping on a car. If I give it full throttle the prop will cavitate, rev very high, than catch water for a moment, drop RPM's, then air again.
I've tried all 6-7 engine "trim" angle positions with similar results. Fwiw, the "top" part of the prop's outer turning radius is about 3" below the transom so I don't believe there's any issue with the Nissan's shaft length. The Saturn rear transom is about 14-15" deep. I believe the Nissan is a short shaft motor.
If we take the time to adjust the engine trim angle just so AND my wife positions herself perfectly fore-aft we can prevent the prop from cavitating and can apply full throttle; however, the bow is high and it won't quite get on a plane. Plus, the boat feels like it's dragging an anchor. Clearly something is wrong.
It cavitates riding solo in all engine trim positions. I only weigh approx. 140 lbs. My wife only weighs 110 lbs.
Just to be clear, the issue is not so much not getting on a plane, but the fact the prop appears to cavitate (and over rev) under med/high throttle conditions.
Do I have a bad prop? Current prop doesn't appear bent. There's some light nicks and wear on the leading edge, but that's about it.
Thanks in advance for any help!
