libellav15
Thread starter- Joined
- Jul 3, 2010
- 177
Info 1972 mercruiser 120 GM in line 4 and pre-alpha leg.
Hi Guys
some advice please - i am going to put a new prop on my pre alpha leg.
i have got the method stright in my head.
but a couple of tips and tricks would be appreciated please.
1) how do you guys stop the prop turning to undo and re-torque the prop nut?
2) is 55lbs torque correct?
3) what grease do you use on the splines?
and this is is confusing me - the tabbed washer currently has the tabs bent down - away from the nut - into the grooves away from the prop nut - how does this stop the prop nut undoing - or is that not the point?
cheers guys
adam
Hi Guys
cheers guys
adam
