Re: Prop compatability. New and just don't get it!
The "Anode" is beneath the anti-vent plate (the horizontal plate just above the prop) made of zinc, but is used for trimming out the engine...besides being a sacrificial element to help in preventing lower unit corrosion...pitting is common....it is commonly referred to as the "trim tab". It's function is to reduce/eliminate steering torque caused by propeller rotational torque. To adjust, loosen and move the rear in the direction the boat wants to go when you take your hand off the wheel at the speed you normally run with the engine tilt in the position you normally run. There is a plastic plug just above it. Remove the plug and look down into the hole. There is a SS hex socket screw down there that is used to adjust it.
If the blades of the prop strike it when you install your new prop, either get a thin one, or take a file and file off the front of the tab until the prop clears it by 1/4 inch.
Splines are the "teeth" on the propshaft....the shaft the prop slides over which mate to the teeth on the inside of the prop hub. A Merc prop of the proper diameter (13+ inches for that engine) will fit Merc prop shafts....I think the spline count is 13 for Merc.
In mounting the prop, grease the shaft, ensure that there is a washer on the shaft that the prop can be pressed up against, the prop, next the locking nut...piece of stamped SS material with a hex stamped to accept the prop nut and tabs on the circumference to lock (3 at a time) into the rear of the prop, then the prop nut which is torqued to 55 ft-lbs.
In installing the prop nut, put a wooden 2x4 between the blade and the anti-vent plate so that you have something to turn against. Put the locking disc on with the hex detent towards the nut so that the nut can go down and into the detent and install the nut. As the nut nears the bottom, you have to hold the locking washer up against the nut so that the nut can go down and into it. 55 ft-lbs is not knuckle breaking tight. It is good and tight, but not strenuous. Once you get the nut tightened, continue to rotate it until 3 of the 6 tangs on the locking washer line up with 3 of the 6 slots in the rear of the prop. Then with a screwdriver and hammer, tap the tangs in place.
Mark
