Prop Contacts Trim Tab Only When In Gear Not Neutral
GTWarrior
Not a merc guy….so not familiar with part numbers other than those noted on the box
Shouldn’t matter. Kit comes with appropriate thrust washer
Ok good, I'll get that kit then. I do believe my outdrive is a gen 2.
Scott06
Normally gen 2 have a flat annode, maybe some of the non PS 3.0 s had them. Either way trim the tab and get on with your boating
GTWarrior
Thank you everyone for the inputs and help. I do belive my problem lies somewhere with the hub kit of prop itself. I took my prob off and then put it into either forward/reverse and then installed back the prop, and it does not jam up on the trim tab.
If I have it fully installed and then put it into forward/reverse then it does hit the trim tab in gear (Forward/Reverse). So I will try the new hub kit with the thrust washer and keep you guys updated.
GTWarrior
Hey guys just wanted to guy you and update. I installed the new hub kit and the issue was solved. After a few process of elimination it seems like the plastic hub that gets pressed into the prop was the problem. Thank you all once again for your help.
