ctf58
- Joined
- Aug 31, 2009
- 33
Here is my situation.
I just got a 1996 16? Stratos 258 with a Evinrude 70hp motor. It has an aluminum 14x17 prop. WOT will go over 6000rpm!!! I have got to get the RPMS down. I just got what I hope to be a good deal, a 13x19 SS prop used but in excellent condition for under $125. I understand more pitch = less RPM, but will less diameter = more RPM.
Speed is not an issue, I'm not in a hurry to get anywhere. 5000 RPMs is about 26mph now and that is fast enough. I just want to make sure I or anyone else that might use the boat does not hurt the engine going to WOT and exceeding 6000RPM.
My question is below
Am I going to be in about the same place because 1" less diameter and more 2" more pitch will cancel each other out??
I understand 2" more pitch should reduce RPMs 200-400. I've heard smaller diameter increases RPMs and SS turn easier in the water than Aluminum and increase RPMs.
What is your thoughts? No one around here has a clue.
Boat loaded is around 2000lbs. That's boat890lbs, motor,gas, 2 people, gear, etc...
Thanks in advance
ctf58
Thanks in advance
ctf58
