Re: prop direction going forward and reverse
on my 2002 Suzuki 40 there is just a high/up, middle/neutral, low/down movement to the shift rod when removing a lower unit I always made sure the shifter was in the highest position to allow ease of making connections. depending on where your linkage connects, if its in neutral or fully down position it may be much harder to make the connections or not at all.
