prop direction going forward and reverse
ggarrett
in what direction does the prop spin in forward and reverse. im trying to restab the lower unit.
Ike-110722
Re: prop direction going forward and reverse
Most are right hand, that is they turn clockwise (prop blade moves to the right at the top) and counter clockwise in reverse.
jestor68
Most use right hand rotation; referred to as "standard" rotation.
Bigger(V-6) outboards and stern drives are available in counter rotating(left hand)versions.
What kind of power package do you have?
ggarrett
power package? its on a suzuki 30 horse, 1989.........
how do i get the lower unit in neutral?
ggarrett
ggarrett
before i took the lower unit out again, the prop was in neutral when the shifter was in forward....
limitout
Banned
on my 2002 Suzuki 40 there is just a high/up, middle/neutral, low/down movement to the shift rod when removing a lower unit I always made sure the shifter was in the highest position to allow ease of making connections. depending on where your linkage connects, if its in neutral or fully down position it may be much harder to make the connections or not at all.
ggarrett
true, harder to connect on some of those positions.
