Prop direction question and Gear oil question
Bustedknuckle84
1) on the motor below which direction does my prop turn? im at work and researching some new props or i would check it out myself.
2) which gear oil do i use and an qucik filling instructions? i already peeped at the screws i see the fill and i see a vent screw. just want to look at it and top it off.
jerryjerry05
Re: Prop direction question and Gear oil question
Right .The fill vent is there to top it off.or fill it after you drain it.
The very bottom of the drive is the drain.There is a screw head on the side you don't want to EVER touch.See pics First is a NO touch The second is the drain.The screw is the linkage pin and will be a bugger to get back in.J
Bustedknuckle84
thanks for the reply! Could you tell me which gear lube to use?
roscoe
Any MARINE gearcase lube will work.
The "Mercury High Performance" stuff is made for i/o's though.
Bustedknuckle84
thanks eveyrone for the replies i have all the research i needed :D
