I have a 19' deep V bowrider with a Mercruiser #1 (888) and about 215 hp 302, recommended wot rpm is 4200. I have two props.
1. 14.25 x 21 cup Michigan wheel aluminum. Runs well, carries load ok, somewhat responsive to trim, minimal-moderate bow lift. Won't back for anything. Hard to control around the dock.Top speed: 48.8 @ ~4050 Engine accelerates well with this prop to midrange.
2. 14.25 x 17 Hustler aluminum, heavy cup. Handles great. Load carrying so-so, pulls hard at mid range thru wot, very responsive to trim, good bow lift. Backs great. easy to control around the dock. Top speed: 46.x @ ~4050
Any suggestions of a prop that combines the best of both? I generally run the Hustler, but would really like the load handling of the MI Wheel. If the MI would back worth a dang, I would run it more.....
