Prop. grease?
rcl700
Is there a special grease I need to put on prop shaft before placing the hub on? Will normal high temp grease work?
Re: Prop. grease?
Ayuh,....
V
V
V
V
V
V
V
V
V
V
V
V
V
V
triumphrick
Re: Prop. grease?
I just love Yamaha blue marine grease...use it for everything...!
MRS
Re: Prop. grease?
I use the merc lube on everything that needs to move. But like someone on this forum always Said (Any Grease is Better,..... Than No Grease at All.......
mpsyamaha
Re: Prop. grease?
OMC triple guard grease or mercury 2-4-C. i love the blue omc stuff, it really lasts
642mx
Re: Prop. grease?
I don't think there is a "special" grease to use... just something water-proof.
rcl700
Re: Prop. grease?
THanks guys I will find some waterproof stuff.
What kind of grease should i use on the end of the steering cable (motor side)
same stuff?
4JawChuck
Re: Prop. grease?
Silicone grease will not wash off and does not mix with water, its what I use on everything marine.
