Prop ID is this a Michigan wheel (HELP)
Bass Runner
I need to ID a prop that is on my 70HP Johnson, it has a number on one blade root that is T-44-309 it also has a number on the end of the hub looks like 3841 and a M inside a square box with a 9 next to it, could it possibly be a Michigan Wheel Prop, by measureing it i know it's a 13" but have no clue what the pitch or manufacture is.
rickdb1boat
Re: Prop ID is this a Michigan wheel (HELP)
That's an OMC prop.... Not sure of the pitch, but I really have not looked around yet. Get back to ya soon.
Bass Runner
I thank you for your help i don't know the pitch on the prop but i want to get another like it, it had a part# on it but don't know how to trace it T-44-309 does the M inside the square mean it a omc?
rickdb1boat
I cannot find those numbers either, but I'm betting it's a 13 X 19" pitch prop. Is the 3841 the only number on the prop? That 3841 does not have any other possible numbers with it? Just 3841 alone? If all else fails and you have a prop shop near you, take it to them and they will tell you right away what you have. What year motor is it?
Bass Runner
That number is on the hub where the M in the square is it also has a number on the base of one of the blades (T44-309) I thought OMC had a M in a circle didn't know they used the square too, the prop works real good on the rig i have i want to get another like it
Bass Runner
OOPS. Forgot the year, it's a 1974 70hp. Sorry :eek:
Bass Runner
Did anyone ever find any info on OMC props? I don't have a prop shop near here. I need to know for sure what the pitch is so i can order a new one. thanks :confused:
