prop info
QC
Re: prop info
Moved this over to the prop section. Not specific to 'toons and you'll get a better shot at some help here. Good luck!
junior1113
Re: prop info
nope diameter is 12.25 for johny and 10.25 for force. might fit on splines but diameter is way to small.
dodge man
Re: prop info
the johnson is not on a pontoon but the force outboard is and im wanting to put the johnson on my toon is their a need to change the prop
junior1113
Re: prop info
give it a shot come back with wot rpms. if no tach get a mini tach. looking for 5500. happy boating
steelespike
Re: prop info
Get a tinytach reasonable,easy to install and will fit any similar motor without regard to stator poles.
dodge man
Re: prop info
is their a specific boat tach or can i just buy one from walmart in the automotiv section
