Re: Prop install help
I have the same problem but with a new prop.
The alpha one gen II leg came with a 16 X 16 cupped prop and it was showing so much wear I replaced it with a Michigan Wheel of the same design.
When you look at the two props from the back, the brass center bearing surface is deeper inset on the new prop.
I put it on the boat and torqued the prop nut using the same thrust bearing as the old prop and found that there is a lot of movement fore and aft on the prop shaft. I'd say at least 1/4 of an inch by guessing.
Do I need a different thrust bearing or did they manufacture the prop wrong?
Thanks for any help guys!
Long time lurker, first time poster.
