Ok this is my latest finding on my pontoon motor prop issues.
20ft toon with a 75hp mariner, total weight at 1850 lbs.
this is with a new tach and an old mph guage hooked to motor.
1. motor down all the way, motor turns 2300rpm at 18 miles per.
2. trimmed motor out until it started to bog, back off by reversing tilt back down until it ran smooth again. motor turned 3000rpm at 20 mph.
3. as toon moved across the water for a distance of a mile or so the rpm picked up to 4200 with mph at 20.
4. then rpm picked up alittle more within another mile to 5000r's, mph20.
5. ran this test three times with same .
6. now, I ran 10 miles on a calm bay and it took 6 gallons of gas also.4 people in Toon with 100lbs of fishing gear , battery, trolling motor.
7. the motor in the best rpm position, water line is 4inchs above the cavition plate.
