prop not turning the spline
joysticks
I'm putting my outdrive back together after replacing the bellows, when the outdrive is still off and I turn the prop- the spline doesn't turn. I am wondering if this is normal or if I missed something. What exactly causes the prop to turn? :confused:
steelespike
Re: prop not turning the spline
The spline is on the prop shaft to engage the prop and drive it.
There is a spline on the top end of the drive shaft that engages the motor.
if you rotate the prop in neutral just the prop and prop shaft will move.
joysticks
Thank you very much for your quick response, I was quite worried :joyous:
