CaliChristy
Thread starter- Joined
- Aug 14, 2023
- 6
I have an OMC stern drive with a Ford 302 motor, when in gear the prop does not turn,therefore the boat goes nowhere. Do you know why this might be happening?
Could be several reasons...the hub has slipped...your gears are shot...shifter isn't putting it in gear...I have an OMC stern drive with a Ford 302 motor, when in gear the prop does not turn,therefore the boat goes nowhere. Do you know why this might be happening?
Where is the shift plate?Moved you to OMC, it's not a prop issue it's a drive or cable issue
Lower shift cable is disconnected/broke/out of adjustment
Does shift plate move when throttle is moved FWD/REV?
under the ESA module, where the upper and lower shift cable come together.Where is the shift plate?
