Prop numbers
Dieter
Hey again guys, my 2002 four winns 180 horizon 4.3 chevy had a dealer installed stainless steel prop on it. When the origional owner bought the boat brand new he had this prop put on. There are no numbers on it anywhere. I have not taken it off yet and plan to within the next week or so. What are the usual locations of the numbers usually? thanks
Bt Doctur
Re: Prop numbers
on the side, back or front of the hub. Run the aluminum, your outdrive will thank you.
steelespike
Re: Prop numbers
You should find numbers near the base of the blades or under the propnut.
