Prop Nut wants to back off
sacalait59
My 78 20hp Mercury prop nut wants to back off. It is a new nut, I allready lost
a prop due to nut backing off. I tighten it down and backs off. Any suggestions?
Chris1956
Honorary Supreme Mariner
Re: Prop Nut wants to back off
The larger Merc Prop nuts are usually nylon lock nuts, with spider washers under them. if you bend down the spiders arms, it slocks the nut to the props. Are you supposed to have this kind?
sacalait59
No I have a lock nut and a with a washer. I think the prop goes first then the washer then the lock nut, right?
Chris1956
The parts list shows just a spacer and prop nut behind the prop. it would seem that either your prop nut is the wrong one, defective or maybe you are not tightening it enough. Why not try some thread locker on the propshaft. make sure the threads are grease free.
sacalait59
I don't think there is a hole for a cotterpin but will check what should the torque be on the nut? Thanks
