triscadek209
Thread starter- Joined
- Apr 16, 2014
- 82
Ok well here's another one for you guys...
I have a 1990 Four Winns 200 Horizon, 5.7L Cobra weighing in at 3,200lbs I purchased a short time ago. I recently had to change my outdrive and for cost reasons went with a 4.3L stern which changed my drive ratio from 21/16 to 21/19.
Before the swap I was able to run 42mph (not WOT) at around 4000 rpm (cruising speed) with a 17" 3 blade. Aluminum. Great holeshot also. I was never able to test for WOT yet as the upper unit failed (due to my incopetence) suddenly during the seasons first test run. Undoubtably it put a huge smile on my face, great speed with plenty in reserve, just sad I never got to see it before it locked up. :-/
Now, with the new gearing in the new drive and with a 19" 4 blade, I'm running 4600 rpm @ 42 MPH WOT :-( with this being an older motor and by listening to the motor I'm most comfortable runnin her around 3600 rpm or lower to be easy on her for cruising speeds and that's only around 33mph. I'm okay with running WOT for short periods of time, just not all the way across the lake unless it's an emergency. Would rather have a cruise speed closer to, if no at 40 mph and top speed at or near 50 mph.
The hole shot was pretty decent with 4 adults, 30 gallons of fuel and a cooler aboard. I will keep the 4 blade 19p for watersports etc however I want more top speed and a higher cruising speed for leisurely cruises. I'm thinking a 23p 3 blade will have me right on the money or no? Do I want a 4 blade 23p going that high in pitch to help with holeshot still?
I only want to buy aluminum for possible danger to the lower unit as I will be traveling to several lakes and a couple I'm unfamiliar to.
