prop options 92 stingray
danheck7
Currently 350 chevy, alpha 1, performer intake, 625 edelbrock, aluminum thumper exhaust, msd ignition. 14.5 x 19p. runs about 4500rpm 50k at wot one person and 10gallons of fuel. I have no complaints but I dont know enough about balancing motors and props for economy and performance. First boat in 20 years and that one was a 35 hp outboard. Any advice or direction to find advice is appreciated.
Tail_Gunner
Re: prop options 92 stingray
Plz post boat size and weight along with the gear ratio...It should be stamped on the outdrive
danheck7
Ayuh,... You want to prop it to 4800rpms at wot...
Not sure what the Ayuh,.. means , but if the advice is good , thank you. Looks like I am pretty close. Next time I am out I will watch the tach closer for a more precise reading. Appreciate your time. I will also get the gear ratio, and weight. the length of the boat is 19.5
Tail_Gunner
"but I dont know enough about balancing motors and props for economy and performance."
Think of it this way..the prop is the final gear in the whole scheme of things.The best you can hope for is a prop that will drive the errr allow the engine to reach the mgf's maxium rpm band ...4800 is a safe bet.
The rest your just stuck with...speed....mpg....and performance characteristics...Now you can fiddle with your carb timing and cams whatever plz's you but its like a car with 1 gear from start to stop..not much to tinker with there.
3 blade props offer the highest speed
4 blades offer the best midrange
There are some differences in econ between the two....But really very little practical difference
http://dictionary.reference.com/browse/a-yuh
a-yuh
  https://secure.reference.com/sso/login_pop.html?source=favorites/ˈeɪ
yə,
eɪˈyʌ/ Show Spelled[ey-yuh, ey-yuh] Show IPA
?interjection New England . (used to express agreement); yes
Here let me get you up to speed: http://www.google.com/#sclient=psy&...=&aql=&oq=&gs_rfai=&pbx=1&fp=207a1c3c62b92b94
:D Pay some attention to that a-yuh...;)
danheck7
a-yuh
yə,
Thank you very much. Never too old to learn something new. Very much appreciate you taking the time to help and educate me. Looking forward to helping others as I learn. God bless and thanks again.
