keysersoce
Thread starter- Joined
- May 30, 2015
- 8
Hello,
Unbeknownst to me I had my stern tie-up rope caught in my prop when I tried to start my boat. It started ok in neutral but then I would shift in gear and the engine would cut off. On the third or fourth time the engine finally stayed on and kept in gear. We hadn’t realized it was the rope until we got back to the dock. We saw the rope had sheared off when we got back to the dock to tie-up. Note, I took it really slow on way back to dock as I wasn’t sure at the time what the problem was. I checked the prop back (while in water) at the dock and no rope was found.
Do you think any damage was done? And do you think I might have a rope cutter installed? Everything I’ve read makes it seem like most people need a knife to cut a rope loose if one gets caught in the prop. I’m especially surprised it sheared the rope off since I barely went over idle on way home.
I have a 2005 Mercruiser 5.0 MPI I/O Bravo.
Thanks!
Thanks!
