Hey guys, need some info. I have a stratos 201 pro 21ft with a 200 Mercury XRI EFI. It had a Mercury High 5 prop 21 pitch 5 blade which was great out of the hole but top end is about 50 mph at 5900 RPM. it also had a problem with porposing at lower speeds. I went to a Power tech 25 ptich 4 blade prop and now i have planing problems when the boat is loaded. My jack plate has the motor up a good bit. i would have to measure for more accuracy. Once i get on plane i run about 57 MPH turning about 5400RPM. Can i adjust the jack plate to help this problem with boat not planing or do I still have a prop problem. This boat is heavy and with both tanks full and livewells full she struggles to get on plane. Any advice without having to buy another prop.
