Prop Performance List
BatDaddy1887
So we hear a lot of people needing advice on which prop will work best for their pontoon boat, much advice is given, but we don't hear many success stories. Let's start a list to use as a database for all of us to use as a guide. List your boat make/size, motor make/size, prop diameter and pitch, how you feel it performs (normal cruising, tube pulling, etc.) and any other info you would like to volunteer (such as how much furniture is on board, gas tank size, WOT rpm's, etc). Perhaps info on other props you've used in the past and how they performed for you.
Here's mine:
1988 Godfrey Aqua Patio 24'
1990 Johnson 115
13.25 x 17 (the only one I have had with this engine)
3 couches, 1 flip-flop seat, 2 batteries (in rear), 29 gal gas tank, 6 gal spare gas tank (usually keep 4 gal in it)
8hp Mariner kicker motor mounted on back next to main engine
1 Bimini top
Top speed with one person: 23 mph
Rated for 5500 rpm @WOT. This prop achieves around 5300 rpm's
I feel that the motor lugs even with just one person. I would like to try different props, maybe find a local prop shop and try some.
This list/database may help some people choose a prop that best suits them.
Reel Kahuna
Your motor's WOT is listed between 4500-5500 rpm. If you want to attain the 5500 rpm, then you need a 15 pitch.
My new to me 28' Party Hut is at the marina and will be pulling it out next week to re-power from the existing Merc 115 2 stroke to a Yamaha 115 4 stroke. I'll be able to post the results afterwards.
1983 ercoa 21'
1983 21' ercoa w/1977 evinrude 70 hp soloas 4 blade 13 pitch 22 mph w/little load.
1983 ercoa 21' 1980 Johnson 115 15 pitch three blade 33 light load
with both motors I ran a 12 gallon tank ,three batteries,hard top with metal barn tin. A lot of fishing gear , lce chest live well,ice chest seats and lawn chairs, wood floor,galvanized cross members, metal transom pan.
the transformation to a tri toon with 24 center toon with built in transom .
all aluminum cross members plus extras,all aluminum plank floor from a tracker toon,33 gallon fuel tank, center fiberglass console w/built in live well,4 batteries,trolling motor,soft top.
1980 Johnson 115 13 pitch 3 blade 30 mph
1985 150 XP evinrude Solos 4 blade 15 pitch 43 mph a 5800 only additional equipment was a minn Kota dh 40 with a 35 pound anchor.
loaded with all the fishing gear ,jug lines and weights 4 people on deck 38 at 5000 .
all speeds was GPS
other prop testing in the near future.
