Prop pitch? How do you measure?
sidenberg
The manual for Force 125 calls for 13" dia. x 19" Pitch propeller as standard. How would I determine what the pitch is on my propeller?
skargo
Banned
Re: Prop pitch? How do you measure?
Mine is stamped on the hub, after the model# xxxxx 19P for example. I have read here that some need to be removed to see the numbers.
sidenberg
Wow. Thanks Skargo. That is easy. I looked on my prop and it says 13 1/2" x 17". Is this good or bad since my manual calls for a 13" x 19"?
skargo
Banned
It depends on if you engine is operating in it's powerband, and if your performance is satisfactory.
If you go to the prop section, you will get a ton of info.
thompy
the 17p is more for towing a skiier or tube, or heavy boat
