I didn't notice anything in the thread you referenced that stated any hardness data; just an opinion that this prop is more "durable" than that prop. And he was comparing Mercury's X7 alloy props to the Raker. No mention of the RakerII compared to the original Raker.
The RakerII is a better performing prop than the original. The miniscule difference in hardness(if it exists) only means that prop is better at chewing up sand and gravel. The Fact(?) that Mercury's X7 alloy may be tougher than BRP's alloy really isn't that important, if you stay off the bottom. If it is, get a Mercury prop.
I guess it depends on what your performance goal is. I prefer the prop that performs best pushing water and stay off the bottom.
Since the OP is presently running a Raker(original) and it isn't performing at the usual motor height, it doesn't make much sense to recommend another original Raker.
The only prop I broke in 30 years was a Mercury X7 alloy prop. Go figure. I guess that rocks aren't impressed by that little difference in hardness.
