Prop Pitch questions
karayj
1989 regal 18.5 Medallion bowrider 3.7LX Merc I think it's the four 470 engine, the serial is 0C520320
Spare prop question. I have a great deal for $40 on a brand-new prop never used and I plan on buying it as a spare but I want to make sure it'll be OK.
Now I do know that depending on the pitch it changes the RPMS what I'm not sure is does it go up or down with the number I currently have a 14.5 19 pitch prop on my boat I'm not sure if that's the right one that came with the boat originally.
I currently have the opportunity to purchase a 14.25 X 21 pitch prop . My understanding it more top end speed and less hole shot which is better. I would rather have top end then hole shot
Rick Stephens
Higher pitch means more load on the motor for a given RPM. In this case top Wide Open Throttle (WOT) RPMs would drop a couple hundred. It may or may not increase speed, really depends on a bunch of other factors like how your current 19 inch pitch performs, difference in blade design , and how how heavy and how much drag your boat has. As a backup it is probably fine, however, if your current 19 pitch prop is in the range that WOT RPMs are below maximum, then going to a higher pitch will just lug the motor and not increase any performance gains.
QBhoy
Can often lose top end with more pitch, depending on what you see now, with less pitch. Some hulls like more rpm from the prop to give a little lift.
