prop pitch
nickster2213
I would like to switch my 13x15 prop on 1980 140hp johnson to a 19 pitch. What kind of performance effect should i see, will it make the old girl work too hard?
jimmbo
Re: prop pitch
If the 15 is presently the proper pitch, allowing the engine to run at the upper end of the WOT range, adding 4 inches of pitch will lower the rpm by about 800 rpm, resulting in poor holeshot and probably lower top speed. If the 15 is allowing the engine to exceed the recommend RPM then adding the 4 inches will still lower the top rpm, which might or might not bring into the recommended range. Top speed might or might not increase
