Re: Prop Problem
it is a yamaha f150 2005 4 stroke.....<br />i had a 14.25 x 17... i needed to raise the rpm from 5000 to 5500 to get her up to WOT.... so i ordered a 14.25 x 15 on ebay...trouble being it is the wrong part #.... 10315 is the merc version the 30315 is the yamaha version....i got the merc version.... ineeded the yamaha .... the hard ware is all different.....thrust washer and lock nut....same amount of splines and diameter...slides right on but shaft is not long enough to get the washer below the nut on to the splines.... thank you all for your replies
