prop problems
houndog
I am new to toons,we bought one 2 weeks agao. the boat was running good then ever once in awhaleit would solw and mahe noise. Back off the throttle and go again,untill the next day went out ,things were good the it reved up. we could go slow ,the porp rubber melted what could cause this. the toon is 24ft 60 hp evenrude
rickdb1boat
Re: prop problems
Normally prop hubs "Spin" due to a underwater strike. But they can also fail for other reasons. Such as if the engine is running too hot, then the exhaust gases that come out through the prop can actually melt the rubber hub or at least weaken it. In any event, take the prop to a prop shop and have it rehubbed. They can probably give you an idea of why it spun. It's also a good idea to always carry a spare prop onboard just in case.
newtooner
Re: prop problems
Thanks for the help,I do not think overheating is the problem,the moter is spitting well
tashasdaddy
Re: prop problems
pervious owner probably hit something. just because you have a good stream, does not mean the thremostats are opening, and cooling the motor.
houndog
Re: prop problems
you may be right i will chech it out this weekend.
Thanks
