witch way does my prop turn? i have had conflicting opnions.
B blueagletalon Seaman Thread starter Joined Aug 6, 2009 Messages 67 Aug 18, 2009 #1 witch way does my prop turn? i have had conflicting opnions.
cooter2506 Senior Chief Petty Officer Joined Apr 8, 2007 Messages 733 Aug 18, 2009 #2 Re: prop quaestion What do you have a single mercruiser or omc or do you have a dual drive set up. More info is needed.
cr2k Captain Joined Mar 19, 2009 Messages 3,730 Aug 19, 2009 #3 Re: prop quaestion Look at the blades. It turns the direction that will screw it forward thru the water. Usually clockwise (from the back of the boat) which is RIGHT HAND DRIVE. Which ever way the TOP of it turns to go forward is what it is called.
B blueagletalon Seaman Thread starter Joined Aug 6, 2009 Messages 67 Aug 19, 2009 #4 Re: prop quaestion cooter2506 said: What do you have a single mercruiser or omc or do you have a dual drive set up. More info is needed. Click to expand... single drive its a 165 mercruiser 3.7 liter
V victorc1 Petty Officer 2nd Class Joined Jul 15, 2009 Messages 133 Aug 19, 2009 #5 Re: prop question Re: prop question It should spin clockwise if you're standing behind the boat looking at it.
