QC
- Joined
- Mar 22, 2005
- 22,783
Re: Prop question - 1989 Sea Ray 300DA
If the same throttle position results in a faster speed, it does not matter how you do it, you are more efficient overall. Just something to think about. Some guys never lift their tabs because their boats are so underpowered it is the only way that they can maintain a plane. This is not bad, it is just the only way to do it with an underpowered boat. If she can plane with more tab and less throttle all is good. And the flow meter would agree.
This is pretty darn good. Since the throttle up situation only happens a couple of times a day, I am confused why improvement here is so important. Also, I would never bring my tabs "all the way up" on a cruiser.I usually tuck the drives all the way down, bottom out the trim tabs, throttle up to about 3/4+, get her up, reset tabs all the way up, trim outdrives, throttle back to 3,000 for a 30 knot cruise.
Same comment about the tabs. If you lift them and she starts to fall off plane, that is significantly more "drag" than the tabs create holding her up . . .I currently need to run minimum about 2,7000 RPM at 25-27 knot cruise otherwise she falls off plane. If I deploy trim tabs and\or trim down the IOs I can hold plane at lower speeds (but with much more "drag").
