prop question
Rob454
Ok guys<br />I have a 89 Bayliner 19 foot Capri open bow. it had a 5 liter v8 and OMC outdrive. I jsut had the motor replaced and it runs great. The only thing is the boat only revs to 36-3700 RPM. but it was sort of rough out that day. It has great pick up off the bottom. Now I looked and i saw the last owner had a 4 blade prob and there is a 3 blade prop in a storage bin. The 3 blade prop looks like it got dragged up a launch ramp or hit something so its unuseable. <br />Now I had jet skis and When you switched to a different prop you could loose as much as 500RPM from the top. Anyway I know a a bunch about jet ski props and wont bore you. Im thinking I should go back to my stock 3 blade prop. I dotn plan on towing skiers and If I do the prop is a snap to change. What is the stock prop for that bayliner?<br /><br />Thanx<br />Rob
SpinnerBait_Nut
Re: prop question
Hey Rob, I will get this to the prop forum, but will leave it open here also.
walleyehed
Re: prop question
I would question tachometer accuracy first...<br />If you went to the expense of replacing the engine, I would go ahead and have a new tach installed...it's the only "true" reference we have...
Rob454
Re: prop question
I had my mechanic buddy with me and he used a timing gun that has a RPM display while we were out and he was showing 100RPM more than the stock tach.<br />Rob
walleyehed
Re: prop question
Yes, and it may be 300-400 off at the proper WOT.<br />100 off at that RPM is quite a bit.
