prop question???
Snap43nib
I need to replace or repair my prop and I'm trying to figure out what pitch my current on is, one of the blades is stamped "A17" would that mean its 17" pitch?
Bifflefan
Re: prop question???
A17 is probably the stamp a repair shop put on it to ID it.
If there are no numbers cast on the hub, and none stamped on the center between the blades, (not the ones you found) then you need to take it to a prop shop and have them gauge it.
They can tell you exactly what it is and if they can repair it again or not.
