prop question
betayv
hello guys I have a 1987 searay I/O with a 260 hp 5.7 engine and a alpha one outdrive I just have the boat couple of months ago, I need a propeller but I don't know what to buy any advice thanks. the boat doesn't have a propeller was like that when I got it.
steelespike
Need the boat size and type.Do you know the gear ratio? Sometimes visible on the out drive.
Prop selection will also depend on your typical load and activities.
Probably going to be pricey. You may want to find a dealer that will let you try some props with the understanding you are buying from them.
Usually requires a sizable deposit.
